Scootergirl Posted May 15, 2019 Posted May 15, 2019 My ISE washing machine is blowing all the fuses in my home when it’s switched on. This happened once before about 2 years ago, and is the only problem that I’ve had with this machine. The cause last time was that the Thermistor was shorting due to moisture, this was because there was a lot of fluff from the tumble dryer which was next to it. I’m not sure what the engineer did, but I know he cleared up all the fluff, and maybe dried the Thermistor out somehow, as he did not charge for any parts. There does not appear to be any fluff at all this time, so not sure what could be causing the same problem.
Root Admin Whitegoodshelp Posted May 16, 2019 Root Admin Posted May 16, 2019 Hello. Tripping or fusing the electrics could be caused by dozens of different things. It also needs a special meter to diagnose this fault - more details and general help here Washing Machine Tripping or Fusing Electrics Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
