All lights are flashing, except “rinse”and “cycle complete”, which are steady and three aren’t illuminated at all. it’s starting the cycle and taking the soap from drawer but then this happens. I’ve tried to use a spin cycle only but it still doesn’t work. Relatively new washer, the filter is not blocked. Please help, too many people in house to not have working washer!
Washer is an indesit innex water balance plus 8kg 1200 spin. Thank you
Flashing lights usually indicate an error code but sometimes they can indicate a problem with the pcb. Could you put a photo up?
Whitegoodshelp please see video, it’s definitely not a blocked filter, I’ve pulled it to bits to make sure. The belt is on and secure and all wires look connected. Thanks for replying.
michelle
It looks a bit like a test mode. Does anything happen if you press start button? Or any other button?
