Hello
my zanussi Electrolux zwx1605w
has stopped working
The on / off button works
I can select a fabric setting
but then the led lights just go out
Its seems to shut down?
the interlock door mechanism works fine ,and the solenoid valves have continuity
any help
After searching on the internet to try and get a fault code
if I press in the reset and start button together,then turn on the washing machine
then release the two buttons and press the fabric button so the led lights up on the 60 c
the washing machine will start drum turns but then stops after about one minute
thanks
It's a long shot but have you tried it in a different wall socket? If the display fades out it could be a power problem.
