MarkF Posted April 7, 2019 Posted April 7, 2019 Our beko has developed a fault, the drum wont fill with water as it just pumps straight back out. What I assume to be the pump is also very noisy. This fault started after the electrical circuit breaker tripped out but this may have happened due to the fault? The timer countdown for the cycle just flashes but doesnt countdown. Any help would be appreciated.
Root Admin Whitegoodshelp Posted April 8, 2019 Root Admin Posted April 8, 2019 If the electrics tripped and then you have these faults it seems likely that yes, something has gone wrong and tripped the electrics but it also damaged something else. Unfortunately this kind of fault isn't something you can deal with. You need an insulation test meter to test the washing machine for insulation faults before you can do anything else. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
