washinator Posted March 20, 2019 Posted March 20, 2019 Hi, I've never had a washing machine before and I'm about to get a new one delivered and I just have one question that no one on the internet seems to be answering....I understand that I must connect the water pipe inlet connection to the tap and then turn the tap to the 'On' position, but when my washing machine is turned off and the washing machine stops water from entering, where does all that water go from the tap that is still in 'On' position? ( I know some people turn it off preventing leaks but I'm asking what stops that flow of water from the tap in 'On' position in the first instance - how does it work? What stops usage of water when the washing machine is off but tap is On, because when I turn the unconnected tap on, the water comes gushing out ? Where does all that gushing out water go, how does it stop my water bill from being astronomical? Does the washing machine somehow create pressure to send the water back up to Thames Water when the washing machine is off or how does it work?)
Root Admin Whitegoodshelp Posted May 10, 2019 Root Admin Posted May 10, 2019 The water valve is just closed so water can't go anywhere and remains under pressure. That's why if the fill hose leaks or bursts you would have a big flood and so it's wise to turn off the taps after use if practical. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
