I need to remove the door on my Bosch WAS24466GB. Two screws hold the hinge in place. Is it safe to remove them or will nuts, or whatever is on the other side, fall inside?
I would rather not have to remove the front cover.
You would need to disconnect the washing machine from the mains. Then remove the front clamp band holding the door seal in place if fitted and then peel away the door seal from the door frame on the casing. This will allow you to put your hand behind whilst unscrewing the screws. You will be able to tell if there is anything to drop down or not. Or you will be able to hold onto it if there is.
Thanks for the update.
