Julesk2510 Posted January 27, 2019 Posted January 27, 2019 Hi I have a iwde7145 washer dryer, when ever I start a wash cycle it trips the main fusebox, was working normally then one day just blown the main fusebox I managed to reset the fusebox when tried to continue the wash cycle it blew the fusebox again, I reset the fusebox and managed to change the cycle to drain and it worked but when tried again to enter wash cycle it continues to blow the fusebox
Root Admin Whitegoodshelp Posted January 28, 2019 Root Admin Posted January 28, 2019 Hello there. Tripping the main fuse box is something that usually needs an engineer to diagnose. There is very little you can do because you need expensive test equipment. However, there are a few things that can be checked as described in my article here Washing Machine Tripping or Fusing Electrics Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Julesk2510 Posted January 29, 2019 Author Posted January 29, 2019 Thanks for the advice, Whitegoodshelp 1
