Hi
I'm trying to fix my Indesit IWME126 which needs a replacement pump.
The current (broken) pump installed is an Askoll M254 but I'm struggling to find this as a spare part for less than £48. There are other Askoll pumps that visually look the same for a lot less.
Does anyone know if there are any alternative part numbers I can use to repair my machine cheaper?
These pumps come up when I search for Indesit pumps - Indesit Drain Pump "Approved Spare" - it's £25
Does it look like the right one?
Yes it looks the same but there are quite a few that look the same and I can't tell what will work and what won't. It says it should work so I should be able to send it back if it won't. Will see when it arrives.
