I have a Bosch WKD28350. Electrics tripped and found out the washer dryer had a bra wire stuck through the drum, removed and now turns ok but needs resetting, Any advice welcome... thanks.... Gez
Hello Gez. A washing machine wouldn't normally need resetting. Once a fault has been properly fixed the washing machine should carry on working as normal.
If you Removed the bra wire but it is still tripping the electrics then the fault has not been fixed. If it is no longer tripping the electrics but it is not working properly then there is still a fault.
Sometimes if the washing machine blows a fuse or the electrics other parts can be damaged. Or alternatively once the fuse is blown the part that caused it has failed completely. It may no longer trip the electrics but it will also cause a different fault on the washing machine. For full advice on this problem read my article here Washing machine blowing fuses or tripping the electrics
Thanks very much andy
I had assumed that there would be a safety cut out on the machine in case of things like this which could have been reset as I know some of them have a reset inside the casing or a reset procedure via the control panel.
