My Miele washing machine is leaking from the bottom left hand corner,near the filter door,  when it empties between the rinse cycles and final spin. I regularly put soda crystals through once every two weeks, I do not use the powder drawer as I use capsules and just throw in the drum. I also clean the filter every two weeks, any ideas please?
Hi. If a washing machine is leaking you have to look where it is coming from. Nothing else can replace that :)
You have to look inside and see where the water is coming from. I have some tips here Washing machine leaking
Hi. Once front cover is dismounted, it will be more visible where water is coming from. Probs from one of two hose connections to the pump.
How old is your machine ?
