noel Posted November 12, 2018 Posted November 12, 2018 I changed a heating element in our Bosch washing machine about 2-3 weeks ago. last night the elcb tripped and I narrowed it down to the washing mahine. As soon as machine turned on elcb would trip. checked as much as possible saw no visible issue with elcb disconnected control board all appears ok elcb does not trip. Then I disconnected the element again all appears ok Machine will function somewhat ( although no heating elemrnt) checked resistane on element pins - measureing about 30ohms - good Check for continiuty between element pins and earth - none - good checked thermostat getting 0 ohms - although must admit - hard to measure At this stage - Im lost - any ideas
Root Admin Whitegoodshelp Posted November 13, 2018 Root Admin Posted November 13, 2018 Fusing or tripping electrics can be many things so it’s not necessarily related to the heater. You wouldn’t expect a new heater go be faulty after 3 weeks. But when you checked continuity between the connectors and earth did you use an insulation test meter? An ordinary continuity meter would pick up a direct short to earth but you need an insulation test meter which puts 500 volts DC through to test properly as described here https://www.whitegoodshelp.co.uk/washing-machine-fusing-electrics/ Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
