Hello all. I've got a Hoover Washer Dryer Dynamic Next (bh4117ai2/2) with a leaking issue. From what I can see it's not the drain. What happens is you put a wash on and as soon as water starts to fill in the detergent drawer a puddle appears on the floor. It's not a little bit of water either it's ALOT. Any suggestions?
Hello. I have a lot of help about finding a water leak on a washing machine. The only way to find where it's coming from is to investigate and  see. There are dozens of places water can leak from. Use my guide here, after reading it there are links to more in depth troubleshooting including an article for leaking from soap dispenser drawer washing machine leaking
Thanks for the reply. It doesn't leak from the drawer though. I took the drawer out and you can see the water coming in and going down then almost immediately from underneath the machine water starts flowing out.
Edit: Never mind. Found something had made it's way past the drum and burst a hole in the tub.
Oh dear. That's usually the end of a washing machine these days. Most people don't realise how just leaving a coin inside a pocket can destroy a modern washing machine. If you have accidental damage house insurance it might be worth claiming?
