ria345 Posted October 9, 2018 Posted October 9, 2018 hi i'm having problems with my washer dryer, the code E10 keeps appearing when i'm trying to dry clothes, however the manual says that this code refers to 'the appliance does not fill with water'. the unit however will fill with water during a normal wash cycle, and complete the cycle with no problems. the error only happens when drying . i have recently cleaned the outlet hose and the filter as we were getting another error code, E20, 'the appliance does not drain the water'. the hose was very clogged, this was the first time we've cleaned it since it was installed in 2013. i also ran a wash cycle with a deep cleaner at 95 degrees. any idea what may be the problem here and how to fix it? thanks rob
Root Admin Whitegoodshelp Posted October 9, 2018 Root Admin Posted October 9, 2018 Hello Rob. A washer dryer should still fill with water on the drying cycle. There is usually a separate valve, which is attached to a plastic condenser chamber at the back of the dryer. The water flow from this valve is restricted so that it only trickles in water. The steam generated by drying the laundry is blown into this condenser chamber where it hits the small jet of cold water. This then converts the steam back into water and it is pumped out. So I would have a look to see if any water is trickling into the back of the condenser when it is on a tumble dryer cycle. As it completes the normal wash and rinse cycle okay it's unlikely there is a problem with the water supply. There could be an electrical problem, or the solenoid in question could be faulty. Another area to consider is that sometimes the water that goes into this condenser chamber is prevented from running into the drum by a blockage of lint or limescale at the bottom of the plastic condenser chamber. I have an article that describes how everything works here Laundry comes out of washer dryer hot & steamy it may or may not be relevant. The faults I describe would normally cause the hot and steamy symptom. But if an error code steps in and aborts the cycle first it could account for it not displaying those symptoms. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
ria345 Posted October 9, 2018 Author Posted October 9, 2018 cheers andy, this looks very helpful, i'll see what i can do. Whitegoodshelp 1
