Sponge Posted October 1, 2018 Posted October 1, 2018 I noticed the other day my drum appeared to be warped, like it had a flat spot. You could see the wobble in relation to the door seal and when it was spinning it would make the machine shake. I couldn't move the drum (which I read was a little test to see if the bearings were shot). Anyway, yesterday we were disturbed by very loud and disturbing noises from the machine as it vibrated, pulsated, on...off...on...off...getting slowly worse. I hesitated to get too close in case the door shattered, but managed to get close enough to turn it off. When I opened the door and started to pull my washing out I burnt my arm on the edge of the drum! It had rubbed against the seal, which was also showing signs of rubber being, well, rubbed, off. The drum still doesn't wobble (bearings), but there is definitely a flat spot/warp in the drum. I've had the machine 11 years or so, so it's out of warranty. I'm hesitant to spend £££ on having it looked at, never mind £££ repaired, as there's probably been other things damaged by the excessive vibration/movement. But at the same time I don't like throwing out something that could be repaired and potentially see us through another few years. I'll try to post a video of the drum to illustrate, but does anyone have any idea what it could be based on my not very good description?
Root Admin Whitegoodshelp Posted October 1, 2018 Root Admin Posted October 1, 2018 Hello there. Are there any dents in the drum that might indicate something has got inside the machine? Dents that come up from the other side? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Sponge Posted October 1, 2018 Author Posted October 1, 2018 Not that spring to mind. I'll take another look tonight and get back to you. Is it possible for an off-balance load to cause such damage?
Root Admin Whitegoodshelp Posted October 1, 2018 Root Admin Posted October 1, 2018 Not really. Especially on a Miele. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Sponge Posted October 1, 2018 Author Posted October 1, 2018 There's no sign of damage, other than what's highlighted in the video. https://www.youtube.com/watch?v=YHxYByJvgFg I've upload a short video to you tube. I've done some more reading and it could be the rear bearing? And it looks like the cost of effecting such a repair and the age of the machine means I may be better off considering a new one. I guess this is the downside of purchasing a Miele - they should last longer, but when they do fail they're often too expensive to repair and effectively written off.
Root Admin Whitegoodshelp Posted October 2, 2018 Root Admin Posted October 2, 2018 That sounds exactly like the drum catching on the door seal. To exclude the possibility try wiping a cloth all around the door seal where it is close to the drum lip soaked in something like WD-40 or maybe some washing up liquid to lubricate it. Be careful not to use too much as some will inevitably get inside the machine. If it definitely isn’t the door seal the only other possibility I can think of is the drum bearing seal but it sounds very loud for that. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Sponge Posted October 6, 2018 Author Posted October 6, 2018 Miele have offered me their fixed price Platinum Care for £249, which will cover parts and labour, repair of any fault and provide a 12 month warranty on the appliance. If they decide to write the machine off rather than repair, they will give me a £249 discount off a replacement machine if ordered through them. Hmm...
Root Admin Whitegoodshelp Posted October 6, 2018 Root Admin Posted October 6, 2018 It would be interesting to see what it was but it’s a lot of money isn’t it? In theory the washer could last another 10 years but it’s a gamble. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
