Rak Posted September 13, 2018 Posted September 13, 2018 Hi I have a Miele washing machine which is about 6 1/2 years old. Recently it has developed a fault "check drain". The problem went away after a reset but has gradually got worse to the point the machine will always display this error message, So I have taken the following steps: 1. cleaned the filtor at the lower lhs sode of the machine. As I have never done this before there was quite a lot of build up. This temperarily fixed the problem 2. I opened up the machine and removed, cleaned the hose from the drum to the filter. The plate which holds the ball (float) had quite alot of build up which I chipped away (hose to drum connection). Also I cleaned the hose from the pump to the drain hose. I tried it on a spin cycle. The machine was definately draining but with1 minute remaining the light came on again. The machine did not go into spin and the cloths were very wet. Can you offer any advise as to how to fix please?
Root Admin Whitegoodshelp Posted September 13, 2018 Root Admin Posted September 13, 2018 Hello Rak. When the check drain error is triggered it usually means there is a partial blockage somewhere (most commonly in the pump filter). That prevents the water being pumped away properly. But if this error occurs when there clearly isn't a blockage then the most likely causes is a blockage in the pressure system. Check out all of my articles about washing machine pressure system and common faults If there is a blockage then it can be cleaned out relatively easily. You need to disconnect the washing machine from the electrics. Access is usually gained by peeling the door seal from the door frame and taking off the front panel of the washing machine. The pressure chamber is usually at the front on most washing machines these days. However, if you take off the lid and locate the pressure switch you can see where the small rubber hose connected to the bottom of it actually goes. If it goes to the back of the washing machine then the pressure chamber will be there. It would normally go to the front. For more details, carefully read the articles I've linked to. If you do try to dismantle the washing machine to get to the pressure chamber make sure you take plenty of photos as you go. It's remarkably easy to believe you will remember how things go back and then completely forget. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
