Hi there,
I want to buy one of these Zanussi washers (ZWF91283W, ZWF81463WH, ZWF71463W). I have a very tight space to fit it in. I know that the actual physical dimensions of washers sometimes vary from the published specifications. Can anyone tell me the exact width of any of these machines? Many thanks in advance for your help.
Best Regards,
Jools.
Hello Jools. Yes you cannot 100% trust the measurements given on websites pages. I have personally seen one or 2 cases where the measurements were totally wrong. I would imagine the vast majority of them are correct, though.
Also bear in mind that if you do order one, and it turns out to have different measurements to those advertised, you can always send it back, but of course that would be extremely inconvenient.
You might find my article on this problem of some use, it has a specific section on washing machine width issues. Ultimately almost every washing machine is the same width give or take a millimetre or so - Problems with washing machine sizes
  • Whitegoodshelp changed the title to What is the width size of Zanussi washing machine?
