Wps Posted August 14, 2018 Posted August 14, 2018 Looking for Advice Aeg washer dryer keeps tripping RCD, no faults showing on machine. Just over 2 years old Pump had failed, Replaced pump, and it did work on test , filled and drained Customer did first load, and it has blown the pump once again after 40 mins If pump disconnected, shows pump error code, RCD not tripping when disconnected. Is this a PCB issue?
Root Admin Whitegoodshelp Posted August 14, 2018 Root Admin Posted August 14, 2018 When you say no faults showing on machine do you mean nothing is showing up on an insulation meter? Also when you say blown the pump, do you mean the pump is literally blown i.e. electrically damaged? Could water some how be getting onto the pump? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Wps Posted August 14, 2018 Author Posted August 14, 2018 Hi Sorry for late reply. No faults on LED display Replaced pump Tested in spin and drain Tested in 90 wash. Left machine as working Customer put first wash in. All ok filled and washed Then at end of wash when starting to drain. Tripped RCD and now the pump motor has blown. Electrical no resistance. Hope this makes sense
Root Admin Whitegoodshelp Posted August 14, 2018 Root Admin Posted August 14, 2018 Hi. Have you got an insulation test meter? You can’t diagnose tripping electrics without one. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Wps Posted August 14, 2018 Author Posted August 14, 2018 I haven't Can go buy one. Or are they costly
Root Admin Whitegoodshelp Posted August 14, 2018 Root Admin Posted August 14, 2018 Aye. Only engineers would normally buy them. Between £200 and £300. But without one you are working blind with fusing and tripping faults - Fusing or tripping electrics Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
