Is it definitely supposed to? If it is and doesn't you'd need to report it as a fault under warranty.
Thanks for the reply. All sorted under warranty - it was a failed magnetic reid door switch. A bit sad that it was failed with out being used once. Even the Miele repairer wasn’t sure in the beginning.
Thanks for the update. It may help someone else down the line.
