ndr2002 Posted June 5, 2018 Posted June 5, 2018 Hi there I have investigated possible sources of the leak using the useful diagnosis tool on this wonderful website but sadly, my problem doesn't appear to be covered... Essentially, the machine leaks from the bottom left corner around the area of the drain pump as soon as a program starts and the machine begins to fill. It positively gushes out of the bottom into the metal tray that forms the base of the machine and I need to turn the machine off immediately to prevent a flood. The machine is quite old but as a supplementary appliance, has been used sparingly and has never had any issues. I have cleaned out the filter and removed and refitted the drain pump assembly to check that the rubber seal is good. The detergent and conditioner drawers are clear of any residue - in fact, detergent (Bold) has only ever been added directly to the wash using a dosing ball. Any suggestions on what specific areas to check would be most welcome as this appears to be a sudden and catastrophic failure of a great appliance!
Root Admin Whitegoodshelp Posted June 6, 2018 Root Admin Posted June 6, 2018 Hi there. It's difficult to advise anything that I haven't already written in my articles about finding out what is leaking on a washing machine - 5 tips to find out where washing machine is leaking from It's literally about observing where the water is coming from, or observing the tell tail water or detergent marks that show where the leak has been running. If water comes out immediately it should be relatively easy to see where it's coming from although a Miele washing machine can be difficult to move about. I would disconnect it from the mains and the plumbing. The ensure all the water has been drained out. Then lay the machine over on it's front and try to take off the back panel and bottom plate if possible to see if you can see a split seal or hole somewhere. If you can't get access to look properly there's nothing you can do except get in an engineer. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
