My Samsung eco bubble 8kg front loader has started to make a strange sound on the rinse only cycle. Doesn’t do this at all on the wash cycle. Spins as normal. Any idea what it is?
its like a click being wound up sound, clicky/springy
Edited by Star_fish
Better title
Normally a noise that happens on the rinse cycle is caused by something rattling around inside the drain pump. Does the noise happen when the washing machine is draining the water, or does it happen while it is actually rinsing the laundry? However, the way you describe the sound, it doesn't sound like the classic something rattling around the pump noise. If you don't think it is something to do with the pump the first thing to do is to disconnect the washing machine from the mains, and then take off the lid and start moving the main outer drum around.
Push it forward and backwards, up-and-down, side to side. This will check if there is anything wrong with the suspension or the chassis. After that, the only thing that could be done is to listen to the sound with the back panel and lid off, which is obviously not recommended unless you know exactly what you are doing, and never leave a washing machine unattended in that state in case someone touches something inside. Only by observing the noise and locating it with your ears can you find out what is causing the noise. I have an article with tips and advice about how to troubleshoot a noisy washing machine
Thank you for your reply.
Yes, it happens whilst it is actually rinsing the clothes, yet doesn’t on the actual wash agitation
I will get my husband to have a closer look via your instructions
You need to observe when on the rinsing it makes the noise. That is, does it make it when it is just gently rinsing the laundry rocking it back-and-forth. Or does it make the noise when it is draining out the water ready to take in more rinse water. If it is the latter the suspect is something rattling about in the pump.
  • 1 year later...
Hy my samsung washing eco bubble makes a lot of noice while draining the clothes .. its produces sound and vibrtes a lot that it tends to chnge its original position..and this is my new  machine plz need help
Hello. Read the advice already given above, it should be relevant. Unusual noise when draining water is a pump fault or something stuck inside the pump and moving about.
