Curious Posted May 16, 2006 Posted May 16, 2006 I wonder if you can help me? My new wave washer (A2142) recently started to show the E1 error code during every wash. I checked the eco ball and the pump, and the water is filling into the machine ok. When I put the washing machine to cold wash it runs ok. How do I get the door seal off to check the heating element as it is fitted at the front of the drum? When I had a Hoover engineer out about 5 years ago he told me that this type of wshing machine was developed to be maintained from the front so I will need to remove the front panel to gain access to the heating element.
Root Admin Whitegoodshelp Posted May 16, 2006 Root Admin Posted May 16, 2006 Make absolutely sure the washing machine is disconnected from the mains supply Take off the plastic clamp band that's holding the door seal on by inserting a small screwdriver under it and gently pulling while at the same time sliding it round clockwise Unpeel the door seal from the door frame On the front panel there are 3 screws near the kickstrip. Then undo the 2 screws holding the door interlock on The panel will now drop down and come away on a Hoover new Wave washing machine Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Curious Posted May 16, 2006 Author Posted May 16, 2006 Thanks for all your help. When I went to remove the wires from the heating element one of the ternimals fell off in my hand. So a quick trip to Halfords and £0.20 later my machine is working great again apart from 1 small problem. When I removed the white plastic ring round the rubber door seal I managed to break it (I think it may have been brittle). Do you know if i can still get 1 of these. and can I still use the washer without it?
Root Admin Whitegoodshelp Posted May 16, 2006 Root Admin Posted May 16, 2006 You can try using the washing machine without it. It's job is to hold the door seal firmly in place and stop it coming undone at the front. If it comes away at any point the door may not close properly. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
