Ojustaboo Posted April 18, 2018 Posted April 18, 2018 HI Samsung eco bubble 7kg, disassembled machine, when I took the drum assembly out from the outer rear drum/bearings, there was an o-ring (or possibly flat rubber) washer, half inside the seal and half inside the bearing. Judging by the shape of it, it has obviously been trapped and squashed out of shape as it should be round (well nothing that shape for it to fit on) . Not sure whether it's a flat washer or an o-ring. I'm going to get a new seal even though I removed the existing one by hitting the bearing from the other side (hence its probably ok) but as I'm replacing the bearings and spider arm, makes sense to do the seal too. I just cant work out where the o ring fits into this, it's the correct diameter to fit on the spider shaft, does it go underneath the seal, is it part of the seal, should it be on top of the seal? Model no is: WF70FSE2W4W/EU Many thanks Attached pic of seal/bearings in back outer drum where washer came from, and pic of both sides and thickness of washer
Root Admin Whitegoodshelp Posted May 22, 2018 Root Admin Posted May 22, 2018 Sorry I haven't replied before. Did you get this sorted? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
