Hi
I have a indesit iwe 7145, I am having to release the water from the filter at the front as it comes up with f05 on about every 2-3 spins, once the water is released it works fine and washes but then on the next cycle it does it again. IV tried to see if it has a blockage and it doesn't. Would it be the water pump not man enough to pump away the water
Since Indesit and Hotpoint are now made by the same manufacturer they share some error codes on some models. If you have a good read about the error code F05 you should get an idea what the problem might be. You'll see that it is possible for there to be a problem with the pressure system and not necessarily a problem with pumping out the water.
