Syllinx Posted March 23, 2018 Posted March 23, 2018 I'm completely new to fixing washing machines. I connected only the cold line to a washer I received just to see if i could get it to wash a shirt since I was told it was broke and nothing else. I simply want to know if water should come out of the hot side back onto the floor if the hot side is not connected, or does this mean the valve is broken.
Root Admin Whitegoodshelp Posted March 23, 2018 Root Admin Posted March 23, 2018 If the hot water valve is activated with no hose connected then water that is trapped inside it will usually drip out of it. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Syllinx Posted March 23, 2018 Author Posted March 23, 2018 It is bad enough that tub seems to fill at normal speed almost but cold water is flowing out hot water at a gallon or two a minute on to the floor. Luckily fill valves are cheap if i have to get one. I will check resistance on hot side when I get home if i can.
Root Admin Whitegoodshelp Posted March 23, 2018 Root Admin Posted March 23, 2018 Hello. I didn't realise there was a lot of water coming out. The way it was worded I took it to mean that you hadn't connected the hot water supply to the hot valve and when you used the washing machine some water dribbled out of the hot valve at the back. That as I replied is normal. But if there is a lot of water flooding out then clearly it's something totally different. With a leak you need to observe where the water is coming from. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
