Hi everyone
I wondered if you could help with an error message I just got on our machine. We can turn it on, all works fine but the machine doesn't spin or turn. I've opened it up, the belt is intact but just not turning so may be the motor?
So it's coming up as h07 error which says that the there is a error with the motor or pcb. I'm leaning to the motor rather then pcb as it turns on okay?
The machine is 7 yearsold, and as it's a Saturday I haven't had a chance to get a quote for repair but is it worth a repair or replacement?
Thank you in advance!
Both motor and pcb can be expensive. Motor fault could just be carbon brushes which would t be too bad. The machine would still turn on and function ok if the pcb has a fault on the motor circuit so you can’t know what the issue is without an engineer looking at it.
