Hary Posted November 28, 2017 Posted November 28, 2017 Recently my hotpoint aqualtis has been cutting out half way through washing cycle, all the lights across the front panel are flashing. An engineer came out changed the heating element, I ran a wash at 60c and this was fine went through complete cycle, then I ran another wash at 40c and the same thing happened stopped half way through all front panel lights on the machine flashing. I ran other wash at 60c again and it was fine completed washing cycle with no issues. Any help or advice would be really appreciated. thank you
Root Admin Whitegoodshelp Posted November 29, 2017 Root Admin Posted November 29, 2017 It could be an intermittent fault and it's coincidence or it could be related to the 40 degree wash. If anything though I'd be less surprised if it worked OK on the 40 but failed on the 60 degree wash because it's a longer and hotter cycle. Ultimately if the fault is still there then they haven't fixed the fault and should deal with it accordingly. To be sure you;d need to run the 2 wash cycles several more times to see if it definitely only does it on the 40 degree cycle. If it does it will greatly help an engineer. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
