webbcooper Posted October 28, 2017 Posted October 28, 2017 Hi my washer/dryer will not start and there's no display. There is power going to the front board but it will not stay on. there is power going every where else.
Root Admin Whitegoodshelp Posted October 29, 2017 Root Admin Posted October 29, 2017 It could be so many things. If there is power going to the board you have at least eliminated a couple of possibilities including blown fuse or no power at the wall socket. There's always a possibility of a neutral fault in the machine or wall socket so power would get to the machine but nothing would work. Make sure you try something else in the wall socket such as a lamp to ensure that is OK. After that this type of fault usually requires tracing with a continuity test meter. If it's not a moulded plug check the plug to make sure neutral wire is OK. Check the neural continuity from the washing machine down to the neutral pin on the plug. Carefully go through everything in this article Washing Machine Won’t Start - after that I;d recommend getting an engineer to look at it. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
