Just replaced the pressure switch but have the same fault code. Have cleaned filter plus pressure tube and pipe. Checked conections etc.
Cn anyone please advise what to try next.
Have you used this article Hotpoint Error Code F05 If error 05 on your machine is the same as the article it looks like you've checked everything though. It's usually either a blockage in the pressure system (actually the most likely), or a faulty pressure switch (relatively rare) or if the machine has not emptied all of the water a blockage in the pump, filter , drain hose, sump hose - or a pump fault.
