Hi I'm having trouble..the machine pumps out once then flashes code 03 I've just tested the current on the pump and that's fine so not sure what else it could be..please help..wife's carrying on as I've bits all over the kitchen..many thanks.Rob
Error 03 should mean the washing machine isn't draining the water (or at least it thinks it isn't). If you can see it isn't draining the water out I have several comprehensive articles on this subject Washing Machine Won’t Drain Water. If by any chance the water is being pumped out there could be a fault on the pressure system stopping the "empty" signal getting through.
