Kim Posted July 10, 2017 Posted July 10, 2017 Lg direct drive washing machine 11yrs old. It spins then gets stuck and then spins again and makes a grinding noise then gets stuck and the drum shudders trying to spin this continues until it sticks completely at 6 mins. Kimberley.
Root Admin Whitegoodshelp Posted July 10, 2017 Root Admin Posted July 10, 2017 The water pump sounds very noisy It sounds like it's pumping water out even long after the water should have gone. Where is the water coming from - it isn't siphoning back up the drain hose from the bath is it? Check the pump filter and pump for obstructions first. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Kim Posted July 10, 2017 Author Posted July 10, 2017 33 minutes ago, Whitegoodshelp (Andy) said: The water pump sounds very noisy It sounds like it's pumping water out even long after the water should have gone. Where is the water coming from - it isn't siphoning back up the drain hose from the bath is it? Check the pump filter and pump for obstructions first. Hi, Water pump, hose, filter etc all ok.
Kim Posted July 12, 2017 Author Posted July 12, 2017 Tried washer with washing in and the grinding noise is much louder, the washer got hot and i could smell burning. Been told it´s the bearings.
Root Admin Whitegoodshelp Posted July 13, 2017 Root Admin Posted July 13, 2017 It's strange because for much of the time the drum is spinning and it sounds perfectly OK, the pump keeps kicking in and out and is very noisy. Then again the drum appears occasionally to judder as if struggling to turn but then at other times perfectly free. If drum bearings have gone normally the drum has a deep rumble on it all the time it is turning and if you spin the drum by hand hard it should sound noisy. If the drum bearings have failed - it should have a 10 year guarantee no? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
