Hi
I have a LG washing machine  F1443kds which keeps cutting out on power
its error code is PF  (power failure)
it takes a few mins after switching off before it comes back on
but it doesn't blow a fuse or trip a breaker
its a direct drive with smart diagnosis  I let it talk to the phone via the app but just says power failure
 It started cutting out during different points of the wash cycle
now I have narrowed it down to the fact it is just cutting out after about 5 mins even if I just turn on the power
all the graphics and sounds work fine all the programs work fine
I am now thinking the pcb  ? But not sure
thanks for any help
Have you tried it in a different wall socket first just in case?
An update
I switched the power on to the Washing machine it took 4 minutes to power off
then after about a minute I can switch it on again
timed it again and it was just over 2 mins
so it seem that if the machine is cold it stays on longer
does it sound like a faulty component on the pcb?
thanks
It could be a fault in the pcb but not guaranteed so it would be too risky to try fitting one. If it's a poor connection somewhere you risk it burning out or even catching fire if left plugged in. I would get an engineer in.
look like that's what's got to happen
the washer is like new and it has a good capacity 11kg
have you heard of this problem before?
It's not too common but you can get main pcb failing.Another possibility could be a fault on the mains suppressor or capacitor but again it's not something I would advise looking at. Let us know if you get an engineer out what it is.
