I have a Bosch Classixx 6 1200 spin washing machine.
It keeps showing a Fault F16. I looked up this fault and it says keep door closed or linen stuck.
I replaced the door lock mechanism with a new one after checking wiring and original door lock and trying all other possibilities.
After putting the machine back together it is still showing the same fault code.
Any ideas about what to do next?
Thanks C
Hello. Where did the fault description come from? It's a strange one to implicate 2 totally different and totally unconnected possible faults. Fault codes can be model specific. The same fault code can mean different things for different model ranges.
Linen stuck presumably means something might be blocking the pump filter? Keep door close implies as you say that it thinks the door isn't shut. A faulty door lock is always possible but as you've ruled it out the other thing to check is that the door latch on the door is OK and securely latching inside the door lock. When does the fault show, straight away or at some point in the cycle?
