Hi my washing machine drum is wobbling inside. They 4 springs that hold the drum are in place. The motor is okay and belt had fallen off. It's the inside of drum that's a problem it's is completely loose and can I fix it as I am unemployed and can't afford new. I can fix myself if it is fixable any advice will be a nocth on karmas belt. thanks guys
If the drum inside is all loose and it threw the belt off it sounds like the drum bearings have collapsed or the drum is broken. Probably not worth repairing to be honest. Many washing machines have sealed drums which are expensive to buy and a very big job to fit.
