hi all, help if possible, washer has started making an horrendous knocking noise while on spin only, have checked weights and all tight and have removed drain pipe and cleaned out and cant find any evidence of a foreign object between inner and outer drums. no noise on any other part of the wash cycle and cant figure out whats wrong. also no excessive play on inner drum to indicate bearing wear. chears.
Knocking noise is almost always a loose weight. There could be a more inaccessible weight on the front or underneath the main drum. With the machine disconnected from the mains and the lid off can you replicate the noise by shaking the outer drum from side to side?  Other than that noises can come from so many places. All the ones I can think of are in this article Noisy washing machine solutions
