First post on here i have a fault with my Beko excellence washing machine.
Its only 3 years old and has now stopped working.
When i select a program and hit start button the machine sounds normal. However it attempts to take water and you hear water going in. Then the door lock icon on the LCD display goes off as if the door is no longer locked it then appears again and seems to repeat the above cycle several times locking unlocking door and dribbling water in. Then after around 10-15 minutes it shows on display as "end" and it hasnt washed a thing.
I suspected blocked water pipes but after having all these off and blown through that's not the problem. My thinking now is maybe faulty computer??
Any help or tips would be great as i can do without the expense of replacing it right now.
What does it doe on a spin only cycle?
