tungmeister Posted January 12, 2017 Posted January 12, 2017 Hi guys, As above the machine seems to be stuck on drain. The pump continually runs even though there's no water left in the system. I've checked the filter and that's fine. I've tried the usual turning off at the wall but as soon as it's powered again and the door is shut it resumes running the pump. There's no error codes being displayed and programs can be started they just never actually start as it keeps draining. Anyone any ideas?
Root Admin Whitegoodshelp Posted January 13, 2017 Root Admin Posted January 13, 2017 Insulation faults can cause strange behaviour. A pump running all the time could also be caused by pressure switch being stuck so the machine thinks it's overfilling. However, I would expect the washer to not take in any water if that was the case. I think an engineer is needed. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
