Andy,
Our Hotpoint WMUD 9427 washing machine recently gave a F05 fault code, after cleaning out the pump filter, pump and flushing through all the hoses I'm now seeing a problem when I try to start any new cycle. The door locked symbol appears as soon as I close the door (which shouldn't be happening until the cycle actually starts) and no water gets brought into the machine. I've carried out a spin cycle after first putting a bucket of water into the drum. This proved that the water drained out and the spin cycle appeared to be carried out correct. Any other cycle I start doesn't do what it should except count down the timer. I should shut the door, press start, at which point the door should lock and water show flow into the drum, not happening.
Any advice you've got would be most appreciated.
Ben
