Hi All
I changed the brushes on a Grand O 6kg washing machine.  But, the machine won't spin.  Fault Code 8 flashes.  Not sure how to procede...
I've checked the wiring to to block supplying power and it looks OK, brushes OK and in contact with armature.  What next?
Hello. Did the washing machine spin before you changed the brushes? In other words are you troubleshooting a fault that you thought was caused by the brushes but replacing them hasn't made any difference or are you troubleshooting a fault whereby after replacing brushes something has gone wrong?
