Hello,
We have a Beko ECO WMB 81445LW that is about two and a half years old. It has stopped draining. I have checked the filter and taken apart the motor and there are no blockages. I have blown down the pressure switch tube and that seems clear. The test function is showing a "04 17" error code. At one point it also flashed up an F8 error code. I have sent two emails to Beko asking about the error code and got no reply (not very good after sales support). Can anyone suggest what the problem might be. The pump motors are quite expensive so I don't want to buy one on spec. Thanks.
Sorry I thought I'd already replied to this. Every possible cause of a washing machine not emptying water is in this article and the links within it. Including what if you can't find a blockage and the filter is clear.
