Hi I have a Beko WM6133s when I load the machine and turn it on the drum does not turn but if i unload the machine then turn it on the drum works any idea what could be wrong or need replacing is this a faulty motor or pcb the machine fills with water and drains as it should thanks
If the drum tries to turn or judders, or the motor makes a crackling or grating noise when it turns the drum (without laundry in) it could be the carbon brushes in the motor if the motor is fitted with them. This fault could also be caused (very rarely) by a very slack drive belt), connection faults, the PCB or main parts in the motor. If the belt is on OK and you can't see anything wrong with connections at the motor plug or the carbon brushes I'd get an appliance engineer.
Carbon brushes diagnostics - do I need to fit new brushes?
Washing machine drum not turning
