Amar S Posted October 10, 2016 Posted October 10, 2016 Hi All. Apologies for the n00b terminology in advance. This is my first post. I have a 6 year old WVD245S3GB bosch washer dryer. There is no problem with the washing cycle, however when the dryer cycle is started (eg auto dry for 2hrs) it pauses after 4 minutes and the door lock gets released but the timer stays at 1.56 I looked on the forum troubleshooting guide and I am not sure if this is a problem with the TOC (not entirely sure what that does) or the thermostats. Most of the engineers are looking for a large call out fee and I read somewhere that if it is a fault with the main board it may not be worth repairing. Has anyone heard of a similar issue before? Thanks in advance
Amar S Posted October 10, 2016 Author Posted October 10, 2016 Sorry I should also mention that no error codes come up on the machine. I also checked the drain filter and there is nothing stuck inside
Root Admin Whitegoodshelp Posted October 12, 2016 Root Admin Posted October 12, 2016 With it sticking on a time and not producing an error code it might be complex or expensive to fix (eg PCB). Sorry I can't be more helpful. Sometimes they can have weird causes but most component faults will produce an error code. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
