I have a Samsung Eco Bubble washing machine which needed a debris filter clean. I pulled out the drain hose to empty the machine but when trying to push back the drain cap the tube shot back into the hole and I can't retrieve it. Any ideas on how I can pull it back out again or is this something that needs a "special tool" repair. Thanks.
Try taking off the plastic kick strip, it normally just levers off (carefully) from the top or may have some screws. You should be able to get better access then.
