Squires89 Posted August 20, 2016 Posted August 20, 2016 I recently changed the interlock as it was shorting out, but now the w/m starts and after a few seconds stops. eg, if I set to spin, machine will spin a few times then stop, if I set to rinse, the inlet valve will open for few secs then stop.!There doesn't seem to be any fault code showing, I've tried different programs, turning off and on, unplugging etc..nothing changes. My guess is the previous short has damaged the pcb. any ideas?
Root Admin Whitegoodshelp Posted August 30, 2016 Root Admin Posted August 30, 2016 Yes it's a possibility that something got damaged but it would be risky to speculatively replace a pcb. It's strange for it to work for a few seconds though. When it stops can you open the door straight away? In other words is the door lock actually locking the door? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
