Wendy Posted August 18, 2016 Posted August 18, 2016 (edited) My machine stops mid cycle and the rinse symbol flashes. I've drained it, cleared out filters. It spins ok and finishes that. It rinses ok if just on a rinse. The problem seems to be when I put it in a full cycle - that's when it stops. It's a BEKO WME8227W Edited August 18, 2016 by Wendy Adding machine make
Root Admin Whitegoodshelp Posted August 19, 2016 Root Admin Posted August 19, 2016 Hello Wendy. A flashing rinse symbol is virtually a universal sign of no cold water available for the rinses. Potentially though it could be a fault on the water valve but check that the cold water supply is actually supplying water to the machine. Make sure the tap hasn't been accidentally turned off. Use this troubleshooting guide for no water going into the machine and then try resetting the machine by pressing the «Start/Pause/Cancel" button for a short time after ensuring that the water supply is OK. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
