Beko 71543B 1500 spin - Please can someone tell me why my machine stops, when I put it on spin & drain on 1500 spin. It starts but when it gets to 12mins, it stops and goes back to15 mins and stops at 12 mins, then goes back again to 15mins. It done that for 21mins yesterday, in the end I shut it off. Can someone HELP PLEASE
If it does it every single time it could be a fault on the pressure system or the pcb or elsewhere so I'd recommend getting an engineer. If it does it sometimes and not others it could be that it can't balance the load. Modern washing machines will try to balance the load before going into a fast spin and if it detects a load isn't balanced properly it can keep stopping and trying again. Quite a few washing machines don't adequately inform the user what's happening. Check this article out just in case but if it's a load balancing problem it shouldn't do it on every load unless there's a fault in the balancing system somewhere - Not spinning some loads
