Ribsta Posted January 24, 2016 Posted January 24, 2016 The m/c starts the washing cycle and tries to fill with water. Then it stops and the symbol of a tap with a line striking through appears. When you press the start button again the cycle carries on. It does this randomly, so you never know when it will happen and it may also do the same on the rinse cycle. Sometimes it doesn't do it at all and carries on through, but its becoming more often now that it stops. I've checked the hose and filter and plenty of pressure on the system. Anyone with an idea to the problem? cheers.
Root Admin Whitegoodshelp Posted January 25, 2016 Root Admin Posted January 25, 2016 It sounds like the washing machine is saying it can't take enough water in. An icon of a tap with a line through it is most likely indicating there is no water available. However, if you can get the wash cycle to complete ok by just turning the machine off and on again that would strongly imply that there is water available and the error indicated is wrong. This article advises on finding out why a washing machine won’t fill with water but it may or may not help. There could be a connection problem or dodgy water valve or even air in the water pipes. When you disconnect the fill hose and run water into a bucket is the water flow smooth with no spurting? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
