Hi all
I have got a bosch wfl 2450 it works all ok on cool washes but when I come to do a 90 degree wash nothing happens the hot valve just hums and that's all any input would be a great help.
Thank you.
Older hot and cold fill washing machines had a separate hot water valve which was usually used exclusively on the boil wash. Sounds like the hot water tap is turned off, the hot fill hose is kinked or there's no hot water running through the hot tap and hose any more. Use this guide ignoring references to cold water and just check the hot supply - when washing machine won’t fill with water
