mrbeatnik Posted December 21, 2015 Posted December 21, 2015 Hi folks, hope you can offer a bit of advice. I've had a wee look around and the advice seems pretty good in here! I've got a washing machine that almost lets no water in the drawer. Result is almost no water in the machine. Manual says it should take a total of 51L overall... no chance! I've performed a few checks: Water inlet valve / hose - no problems, good pressure, good flow. Filter in back of washing machine inlet - no problem, clean - took out and cleaned anyway. I noticed when I took the filter out that there is what looks like a black rubber stopper with a small hole in right at the back of the inlet on the washing machine. I'm wondering if this should be there? I mean it's a hole smaller than a pencil width, or thereabouts. It seems like a silly hole to push water through. We inherited the washing machine with the house, and upgraded the plumbing since... so I was curious if this was some type of pressure enhancer used when they had a water tank (small hole increases pressure, but reduces amount of water taken in). Can I remove it? I can't find anything relating to this in the manual, and have no idea what to call it. Other info - only cold water hose attached. I can also add water through the drawer and it does fill the WM, so it's not going down the drain directly. It really is a low flow somewhere between the cold water INTAKE on the back of the WM, and the drawer. Any takers? I know this is a basic machine, but it seems silly to replace it completely when it appears to work fine in all other respects (aside from the mammoth ~2hr 20min washing cycle)... Thanks!
Root Admin Whitegoodshelp Posted December 22, 2015 Root Admin Posted December 22, 2015 The black rubber behind the filter is to reduce the pressure down and should be there. It's fitted to cold water valves, some of which have high water pressure that needs taming. I have in the past removed it in cases where the water pressure supply was very poor and it helped to increase the water flow a little but if you have normal water pressure it shouldn't need removing and isn't related to your fault if the washer has worked ok before. If the washing machine is otherwise working ok there may well be nothing wrong. If not enough water gets into the machine it should fail to work or abort with an error code. Many modern washing machines hardly use any water at all during the wash cycle and it's normal to hardly see any. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
mrbeatnik Posted December 22, 2015 Author Posted December 22, 2015 The black rubber behind the filter is to reduce the pressure down and should be there. It's fitted to cold water valves, some of which have high water pressure that needs taming. I have in the past removed it in cases where the water pressure supply was very poor and it helped to increase the water flow a little but if you have normal water pressure it shouldn't need removing and isn't related to your fault if the washer has worked ok before. If the washing machine is otherwise working ok there may well be nothing wrong. If not enough water gets into the machine it should fail to work or abort with an error code. Many modern washing machines hardly use any water at all during the wash cycle and it's normal to hardly see any. Thanks for the reply. I've seen a video online of the washing machine going through the diagnostic tests, and the water that fill the tray comes out at a good speed. In my washing machine the water doesn't come out ... very much at all. Trickles. I'm unsure if the machine senses that "enough" water comes through, and it certainly does not take in the suggested amount in the manual for the specific programs, I'm certain. Oh well, at least I know what the rubber thing is for. Perhaps time for a new machine.
Root Admin Whitegoodshelp Posted December 22, 2015 Root Admin Posted December 22, 2015 If the water isn't going into the soap drawer at a reasonable flow rate but the water supply is ok and there's no hose kinking when you push the machine back plus the water filter is clean then I'd have to suspect a problem with the water valve. They normally either work or not but it could be caked with limescale or something inside. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
