Hello all, No water entering machine although both hot & cold supply service is good. Machine has not been run for over 12months. Frustrating day removing and cleaning both hot & cold water solenoid valves. Both appeared clean and in good condition. When I switch on the machine to any cycle, I get a "click" noise, then nothing. When I spun the programme dial while it was switched on it tripped the mains power at the distribution board. Thought I should seek some further advice. Confused why it would throw the mains. Is it likely to be the pressure switch?
It's always possible for appliances to mysteriously develop faults when not used for long periods. It's mysterious and very annoying. Does the machine work on a spin only cycle?
