Hi, my washing machine trips electric on 1200 1000 spin but is ok on 800 iv searched forums but havent found any similar problems, iv taken the motor out there was some plastic inside chewed up which i removed cleaned it out but couldnt test it ordered a multi tester, iv seen a video and there is a speed sensor on the motor, do u think this might be the problem? Iv searched for a replacement part but cant find any, id appreciate any help thankyou
This article explains basic fault finding and the limitations for diy fault finding on fusing or tripping washing machines
If it only trips on the fast spins but not on 800 spin I'd suspect either the motor (is it sparking excessively just before it trips?) or something shorting out when the drum bounces about on faster spins or even a leak getting worse on faster spins and shorting something. The first thing that needs checking is the insulation but as my article points out you can't do that without a proper insulation test meter. After that it's about carefully examining the machine and observing it.
